Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 MKII – CD spinning in reverse
- This topic has 2 replies, 2 voices, and was last updated 7 months, 3 weeks ago by
jo.
31 July 2025 at 07:16 #68051
jo
MemberI was hoping somebody could give me some advice with the CD error I am currently encounter on my Beosound 9000 MKII. Some months ago, I have exchanged the laser unit which helped. CD player then worked mostly after a while; it seemed like after the system had warmed up. Now, after several month of not using the system, I have tried to play a CD again, the CD spins backward and then the CD player goes into PAUSE. In Test mode with Nr TM73, after the TM71 is successfully completed, it spins in reverse too but the error there is CD Error 2. When checking in test mode under TM27 the errors showing are CD Error 2 and under APS, the error it shows Nr 15 which is something to do with timing / auto positioning which has taken longer than 5sec. Has anybody ever had the same experience? Any input would be very much appreciated.
31 July 2025 at 08:48 #68057 matadorModeratorHi,
How was the laser changed, by whom and sourced where?
9 August 2025 at 11:05 #68664jo
MemberThank you matador
Sorry for the late response – currently travelling.
The laser was changed by me, and I followed mostly the instructions – manual. I have purchased the laser from a dealer in Germany – a new unit and I have found it online. As I have mentioned earlier, the laser did work after the exchange but only when the system somehow warmed up (I guess) However after CD player had not been used for a longer period, the CD Player is now not functioning anymore – spinning backwards.
Thank you
Roman
