Home › Forums › Product Discussion & Questions › BeoSound › BeoSound 9000 Mk3 White LE
- This topic has 7 replies, 5 voices, and was last updated 1 year, 7 months ago by
Valve1.
1 May 2024 at 23:07 #32754
The Escapist
BRONZE MemberDear members
I’m delighted to be a member here and get some advice on my products.
My latest purchase is a Mk3 BeoSound 9000 white LE.
My question is regarding the serial number and edition number. I. Puzzled as I would have tonight they’d match but the dealer told me they don’t.
it seems a big coincidence to me that one is xxx19 and the other xxx18, but maybe I’m thinking too much! Pictures below.
The unit doesn’t come with any paperwork so I’m in the dark as to the background but the dealer tells me it has been serviced and has a new laser. He is providing a 12 month warrnty and has a very good reputation, it would seem, so I went for it as the price was good and condition is excellent.
Thanks in advance.
You must be logged in to view attached files.13 June 2024 at 04:13 #56459 Severed_hand_of_skywalkerBRONZE MemberSounds odd to me I would ask the dealer about that. Maybe something harmless or maybe a misunderstanding. Maybe when they were servicing them they got the round plate mixed up.
13 June 2024 at 12:24 #56464Glitch
BRONZE Memberit seems a big coincidence to me that one is xxx19 and the other xxx18, but maybe I’m thinking too much! Pictures below.
Maybe it is as simple as the serial number starting index from zero and the edition number starting index from one.
Glitch
14 June 2024 at 06:53 #56475Valve1
GOLD MemberI have a white 9000 so I will check these numbers but it will be at least a month before I see it again .
20 June 2024 at 23:07 #56637Chucky
BRONZE MemberYour numbers seem strange. Sorry my item number is 1250017 and serial starts with 2201. I have number 70x
I checked mine at my dealer when I bought it of someone.
do you have the red button on top? A bit onreal but I bought another one it is coming tomorrow I will look again to verify. This unit should be ok as I checked it again with my dealer and bought it of Catawiki.
21 June 2024 at 20:35 #56676Chucky
BRONZE MemberYes the other one same item number, it is a 3xx number with serial 214xxxx
19 August 2024 at 11:00 #58445Valve1
GOLD MemberI finally got back to my BS9000 and 35 c- hot !
I can explain your numbers. Look at the photo
The first two sets of numbers are identical, so it was a coincidence that you had 19 and 18.
Hope this helps you sleep better 🙂
20 August 2024 at 06:10 #58468Valve1
GOLD MemberMy bad ! I forgot to explain that the photo in my last post is a photo of my serial/edition number of my white 9000.
