Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 MK3 glass door open issue
- This topic has 4 replies, 4 voices, and was last updated 1 year, 8 months ago by
lesbart.
19 November 2022 at 09:01 #40911
Pindsen
BRONZE MemberHi,
I have a Beosound 9000 mk3 with two issues regarding the glass door mechanisme:
1) Pushing the glass panel button does not respond the first time, it requires several presses before the glass panel opens.
2) The BS9000 is in slant position and when it opens up the glass panel it stops halfway but the motor keeps trying, is it a belt issue?.
If so where to find such and is it easy to replace yourself?/Pindsen
19 November 2022 at 21:50 #4091220 November 2022 at 17:30 #40913Pindsen
BRONZE MemberHi,
Thank you. As far as I can see Beoparts-shop does not have a belt for a BS9000 and I am a little unsure if those sold on Ebay are correct in specification (Maybe Dillen knows)?
/Pindsen
13 May 2024 at 21:41 #55583beomedia
BRONZE MemberHi Pindsen, did you find a belt in the end?
If so could you share the source please as I’m in the same boat looking for a new belt. Suspect many owners will be eventually and I don’t know where one can order new parts from B&O.
Thanks15 June 2024 at 10:18 #56509 lesbartSILVER MemberHi BeoMedia,
I bought this belt, more than 1 year ago, on ebay from this shop:
https://www.ebay.com/itm/334968691736
Installed without any troubles and since then, my BeoSound 9000 has perfect door./Les
