Home › Forums › BeoWorld around the world! › North America › Beosound 9000 MK2 problem
- This topic has 5 replies, 3 voices, and was last updated 3 years, 8 months ago by
mokummer.
18 June 2022 at 04:40 #35575
mokummer
BRONZE MemberJust bought it from the first owner but untested from the wall . Sometimes it works okay but mostly not . The problem comes with the Lid not lifting the glass good enough and the cd player reaction is also bad . Been measuring the voltage on the tray motor (glass ) and the voltage is around 8 volts so lower as needed I think . I think because off sometimes proper working (tray and cd player) that maybe the power supply acts up . So any idea about the power supply and mostly the problems from it ? Thanks
20 June 2022 at 07:28 #35576 spassmakerBRONZE MemberHi
Don’t know exactly what voltage shoud be on the motor, but most times the rubber belt of the geardrive is worn.
try to HELP the glassplate by hand (DO NOT FORCE just help) and look what’s happening.
How is the unit mounted? Horizontal wallmount?
Let us know…
20 June 2022 at 09:21 #35577mokummer
BRONZE MemberThe lid sometimes works but then the voltage is around 9 volts on the motor (slow working was below 7 volts measured. But I have just been re soldering the Motor Control unit at the parts on the cooling plate mounted . And slow working because without anything further mounted . But in slow time it’s plays the cd and is doing his moves from one cd to the other . So maybe it’s solved now for the time being ? And maybe a problem that is happening more on these older equipment nowadays ?
20 June 2022 at 16:41 #35578mokummer
BRONZE MemberMy are getting totally crazy about Beosound 9000 and played perfectly all afternoon and after putting it standby so the same non function cd and lid again . So must be somewhere else but I.am done with this kind off equipment from B and O . So for sale at EBay soon and never again a Beosound 9000
31 July 2022 at 21:37 #35579kronzilla
BRONZE MemberThat is the reason i never wanteda bs9000. Not so durable as the Beosystem 9500 ( okay tape and one cd) but build like a tank and the laser is extremely durable (Philips CDM2, same as beogram cd5500) still plays after 32y without any reparation ( just replaced some belts from the sliding doors and tape)
1 August 2022 at 08:12 #35580mokummer
BRONZE MemberI share your opinion and totally cured about this 6 cd wonder . So not for me
