Home › Forums › Product Discussion & Questions › BeoSound › Beosound 9000 glass door appears to sit too low/push down
- This topic has 4 replies, 4 voices, and was last updated 3 days, 11 hours ago by
Igor Jané.
4 December 2023 at 11:48 #51064
Bee_Dup
BRONZE MemberJust bought one of these. The glass sits too low and touches the CD mechanism making the assembly jitter between CDs and make clickingnoises when playing. Everything works smooth and quiet when i slightly lift the glass door manually. What could have caused this -and do anyone have ideas for a fix? Apparently it has barely ever been used, and sat in a closet/cabinet most its life
20 May 2024 at 06:18 #55784cucoloris
BRONZE MemberDid you solve the problem? I have a unit with the same problem …
thank you
30 March 2025 at 15:17 #64779Igor Jané
BRONZE MemberHello. I have the same problem, did you find the solution? Thanks a lot in advance 👍
31 March 2025 at 15:07 #64794ModeratorCheck service manual (available here for silver and gold members) for glass door height/angle adjusment.
Two Screws, easy work.Location: Paris France31 March 2025 at 15:55 #64796Igor Jané
BRONZE MemberHello! Thanks a lot, it solved the issue 👍🏻
