Home Forums Product Discussion & Questions BeoSound BEOSOUND 9000 becomes mute
  • #73951
    edo69
    Hello, I am a proud owner of a Beosound 9000 since 2002. It always worked fine, just 6 years ago I had to replace the laser lens. Everything fine till last week, when it started to be in trouble. The problem is that when I switch it ON, it starts playing music for about 20-40 seconds, then silence, despite the CD keep turning. If I switch it OFF, then ON, he is totally mute. If I make a reset, pressing the button OFF+CD6, he starts playing again, but just for 20-40 seconds. The other sources (Radio, N. Radio and N. Music) works perfectly. Does someone know what happened and how to fix the problem? Thanks in advance to whom will reply.
    • This topic was modified 4 days, 15 hours ago by edo69.
    Favourite Product: Beosound 9000
    #74228
    beosthlm
    Have you tried the test mode and see what that reports? See e.g., https://archivedforum.beoworld.org/forums/t/24372.aspx
