Home › Forums › Product Discussion & Questions › BeoSound › BEOSOUND 9000 becomes mute
- This topic has 4 replies, 2 voices, and was last updated 1 month ago by
edo69.
18 February 2026 at 11:07 #73951
edo69
BRONZE MemberHello, I am a proud owner of a Beosound 9000 since 2002. It always worked fine, just 6 years ago I had to replace the laser lens. Everything fine till last week, when it started to be in trouble. The problem is that when I switch it ON, it starts playing music for about 20-40 seconds, then silence, despite the CD keep turning. If I switch it OFF, then ON, he is totally mute. If I make a reset, pressing the button OFF+CD6, he starts playing again, but just for 20-40 seconds. The other sources (Radio, N. Radio and N. Music) works perfectly. Does someone know what happened and how to fix the problem? Thanks in advance to whom will reply.
Favourite Product: beosound 9000
22 February 2026 at 14:16 #74228beosthlm
BRONZE MemberHave you tried the test mode and see what that reports? See e.g., https://archivedforum.beoworld.org/forums/t/24372.aspx
2 March 2026 at 10:42 #74659edo69
BRONZE MemberHello. thank you a lot; I will run the test and I will post the result.
3 March 2026 at 11:42 #74787edo69
BRONZE MemberIt is sure: the output board is KO; does someone know where can I find a new one?
9 March 2026 at 11:05 #76281 -
