Home › Forums › Product Discussion & Questions › BeoSound › Beosound 8 no longer connecting to wifi
- This topic has 4 replies, 3 voices, and was last updated 3 years, 1 month ago by
Leosgonewild.
6 March 2023 at 03:59 #44351
nic67
BRONZE MemberHello All
I have had a Beosound 8 for about 10 years it has worked seamlessly over the wifi however since changing my router I cannot seem to reconnect it.
Any thought on this would be appreciated.
Nic
Favourite Product: Beosystem 5500
6 March 2023 at 17:21 #44352 MillemisBRONZE MemberThe Beosound 8 never had a wifi/network connection option.
6 March 2023 at 18:04 #44353nic67
BRONZE MemberHi Sorry It is the Beoplay A8
7 March 2023 at 14:34 #44354 MillemisBRONZE MemberWhen I had my A8, it was running on wifi – so that should not be a problem.
The problem is your new router/the settings.
Hard to say anything, when one does not know the brand, the settings, the strenghts of the signal.After resetting it, I would try connecting it with a cable – that some times helps and can give you access to the menu for the wifi password.
Use the Bang & Olufsen app to set it up.MM
10 March 2023 at 14:26 #44355 LeosgonewildBRONZE MemberA8 is 2.4 ghz. Is your new network only running 5ghz maybe?
