Home Forums Product Discussion & Questions BeoSound Beosound 5 – edit radio stations (BBC)
  • #64939
    Frog
    GOLD Member
    I’m trying to edit the Beosound 5 radio channels. Firstly, I got the radio.db file from the Beomaster 5 by firstly going into the service menu, then getting the file located in E:/cache/data.
    I have a list of direct links to radio stations used by the BBC here (in HLS):
    https://garfnet.org.uk/cms/tables/radio-frequencies/internet-radio-player/bbc-national-and-local-radio-hls-streams/
    I then edited the file using a database editor and altered the station table with the BBC Radio 4 urls column to be
    https://lstn.lv/bbcradio.m3u8?station=bbc_radio_fourfm%22&bitrate=128000%22
    This link worked on my computer (I altered to bitrate to 128,000 as I heard that the beomaster 5 couldn’t handle higher streams somewhere…
    I then saved the file, put the new one back into the location of the old one and rebooted the beomaster 5.
    Unfortunately, it didn’t work 🙁
    I’ve tried with HLS and DASH streams – and downloading firefox 13 onto the Beomaster 5, I tried opening the stream – this didn’t work because it wasn’t happy with the https, so I changed the link to http – and it got the playlist, but couldn’t play it . I tried the link in the installed Windows Media Player and it said it couldn’t handle a m3u8 file.
    I guess the issue is with the codec support in the OS and not being able to recognise a m3u8 playlist file
    #125090
    edo69
    Hello, I have readen your thread, ’cause I am having the problem of some n.radio, present in the menu, but when I select, the logo blinks for hours, and no streaming.
    Hope you got to fix the problem; aniway is a shame that B&O does not support anymore this product; a B&O device should be forever.
    Evidently B&O is no more the same we are used to know.
    Favourite Product: Beosound 9000
