Home › Forums › Product Discussion & Questions › BeoSound › Beosound 5 – edit radio stations (BBC)
- This topic has 0 replies, 1 voice, and was last updated 1 year ago by
Frog.
4 April 2025 at 14:29 #64939
Frog
GOLD MemberHi,
I’m trying to edit the Beosound 5 radio channels. Firstly, I got the radio.db file from the Beomaster 5 by firstly going into the service menu, then getting the file located in E:/cache/data.
I have a list of direct links to radio stations used by the BBC here (in HLS):
I then edited the file using a database editor and altered the station table with the BBC Radio 4 urls column to be
https://lstn.lv/bbcradio.m3u8?station=bbc_radio_fourfm%22&bitrate=128000%22
This link worked on my computer (I altered to bitrate to 128,000 as I heard that the beomaster 5 couldn’t handle higher streams somewhere…
I then saved the file, put the new one back into the location of the old one and rebooted the beomaster 5.
Unfortunately, it didn’t work 🙁
I’ve tried with HLS and DASH streams – and downloading firefox 13 onto the Beomaster 5, I tried opening the stream – this didn’t work because it wasn’t happy with the https, so I changed the link to http – and it got the playlist, but couldn’t play it . I tried the link in the installed Windows Media Player and it said it couldn’t handle a m3u8 file.
I guess the issue is with the codec support in the OS and not being able to recognise a m3u8 playlist file
