Home Forums Product Discussion & Questions BeoSound Beosound 4000 “Disc Motor Does Not Start” Transport Issue
  • #69899
    jacope
    Hi all,
    I have a Beosound 4000 with a disc reading issue. This unit has the CDM12-IND laser with the later board iterations (PCB89 instead of PCB8). I have repaired a lot of these units and I do not believe it to be related to the laser.
    When CD is pressed, the display changes to “CD” or “CD <>”, the laser attempts focus, but does not spin AT ALL. Typically with laser issues, the drive will spin a few times and then stop.
    In testmode it will attepmt focus, I can get the laser sledge to move back and forth, and I can get the disc to spin all on their own, but nothing happens in the CD-specific test procedure. I am not able to get any CD error codes from testmode because of this issue.
    In the “New Version CDM12” service manual it states:
    Disc motor does not start: If focus is searched and the laser switches on, and yet the disc motor does not rotate, the error is probably in the transport mechanism itself. For
    further service tips, see section 5 (section 7 as regards Beocenter/
    Beosystem 2500-2300).
    This states to reference section 5 (or 7), but transport issues are not specifically mentioned here.
    Any insight would be amazing, thanks!
    My B&O Icons: No description availableNo description availableNo description availableNo description available No description available No description available
    #69907
    Madskp
    GOLD Member
    Hello
    I had something similar going on with my BS Ouverture over in this thread https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50361 I started with cleaning the laser, and later replaced it which did change some of the behavioiur, but could still not get it to play. I then recapped the board on the back of the CD mechanism which helped getting it to play:  https://forum.beoworld.org/forums/topic/beosound-ouverture-cd-not-working/#post-50369
    However it had and still have the issue that I most times has to press CD twice to get it to play, but other than that no issues.
    Maybe you can find something usefull in that thread.
    I have also noticed the lack of these chapters for the newer type of CD mechanism in the servicemanuals available on Beoworld. Would be nice if someone had a fully updated version of this service manual. Maybe @Multicare has something that is not uploaded to the product section yet?
