Home › Forums › Product Discussion & Questions › BeoSound › Beosound 1 (BT/WiFi): No more local control.
- This topic has 5 replies, 3 voices, and was last updated 2 years, 11 months ago by
trackbeo.
8 May 2023 at 08:02 #46384
T.W.GGOLD MemberMy Beosound 1 (Bluetooth/Wifi) doesn’t react anymore to local control. I can tap on the top or turn the wheel: Doesn’t work. The LEDs are off, too.
I’ve reset it multiple times, no success.
BUT: It starts via Bluetooth remote or Wifi control (app and remote) and is controllable.Some data:
– Beosound 1
– Item No. 1665511
– Software: 2.1.50868.22855122
– Status -> Critical events: Battery level is critical, SHUT DOWN! (This message is shown multiple times in the protocol)I think I’m somehow out of luck with some B&O products despite my love of it. 🙂
8 May 2023 at 08:35 #46385Die_Bogener
BRONZE Member… and why dont’t you replace the battery? Or is the AC charging tool defect?
It’s a lithium battery. That’s no fun… it can burn or explode…
9 May 2023 at 07:25 #46386 T.W.GGOLD MemberIs there a service manual on how to dismantle it WITHOUT scratching and damaging? 🙂 Didn’t find one on Beoworld nor online, only for the lovely old Beosound 1 with CD player.
Can anybody tell me if my BS 1 item no. 1665511 is MK1 or MK2? There are two different batteries available.
Currently I didn’t disassemble the BS 1 so I can’t tell whether the internal charging circuit is dead or just the battery.
It’s strange that local control is broken… and even stranger if this has its cause in a broken battery.
Yes, I know that lithium batterys aren’t fun. That’s why I don’t buy an electrical car, too. 😉
9 May 2023 at 07:38 #46387 trackbeoBRONZE MemberProbably a Mk.1. My Mk.2 says item no. 1665522. But it’s also easy to tell without guessing at decoding numbers: If your Beosound 1 were a Mk.2 the label on the bottom (line 2) would say, “Model: BeoSound 1 2nd generation”.
9 May 2023 at 08:07 #46388 T.W.GGOLD MemberModel: BeoSound 1 2nd generation”.
Okay, that was too obvious. 😀 Thanks.
So, MK1 battery required and service manual.
10 May 2023 at 19:31 #46389 trackbeoBRONZE MemberI’ll do a Gold Membership again if you actually get a service manual, and give it to Lee or Keith to scan! In the meantime, here’s a take-apart video: https://www.youtube.com/watch?v=6sF3mNfomxI (The Vietnamese subtitles and auto-translation are weak. Notice that he had already removed the antenna connectors and also taped up the metal surround for prying. It’s a 2nd-gen.) Last week on the BeoTalk stream, @Mikipedia mentioned the 3 bottom plastic covers break easily and @Beowillie confirmed, saying he kept spares in his parts stash.
