Home › Forums › Product Discussion & Questions › BeoSound › BeoSound Century AUX connexion
- This topic has 1 reply, 2 voices, and was last updated 1 year, 2 months ago by
pepps.
1 February 2025 at 17:57 #63296
Robert Cox
BRONZE MemberWhen I plug an Internet radio or Cocktail Audio music library into the AUX plug of my BeoSound Century, there is only a loud static noise. This used to work perfectly until 13 months ago. The local B&O agent has repaired it three times. But after a week of so, the static noise returns. I have replaced the connecting cable,but that does not help. Can anyone suggest the cause and solution? Many thanks.
6 February 2025 at 11:19 #63456 peppsModeratorI would call your B&O contact and ask them to explain what they actually repaired each time. That should help you understand what may be wrong – perhaps between you both you could suss out a long term fix?
Favourite Product: Beosystem 6500
