Home › Forums › Product Discussion & Questions › BeoSound › Beosaund Emerge
- This topic has 6 replies, 4 voices, and was last updated 2 years, 11 months ago by
Millemis.
8 April 2023 at 06:22 #45619
Vedet
BRONZE MemberGood afternoon! I want to ask if it is possible to use the beoremone one remote control with Beosaund Emerge to turn on/off, control the sound and switch radio stations, the list of which I have selected and saved in the B&O App. I would like to make all the settings in the application, select and create a list of Internet radio stations, and use the beoremote one remote control for everyday use. Is this option possible, or is BS Emerge managed exclusively using the B&O App via a phone or tablet?
8 April 2023 at 20:09 #45620 YannChrisGOLD MemberHi,
According to the B&O website, BR1 can be paired with Emerge.
Check this:
Kind regards,
Yann.
8 April 2023 at 21:30 #45621Razlaw
BRONZE MemberI use a BR1 paired with a pair of Emerges.
9 April 2023 at 01:31 #45622Vedet
BRONZE MemberVery cool! Tell me in more detail how do you use BR one? How do you synchronize the selected list of radio stations in the application with the remote, do you switch radio stations from the remote? The selected radio stations, for example B&O radio in the application, are synchronized, reflected on the remote display and when you press the “music” button, you can see the list of radio stations from the application on the remote display and change them using the arrows of the BR one remote? Or is it happening in some other way?
9 April 2023 at 09:40 #45623 MillemisBRONZE MemberActually it is quite simple.
Supposed you have made a list of your favourite B&O Radio stations in the app….
After you have set up the Beoremote with the actual product – using the app – this list will be available in the display of the remote, when you choose radio (from the Music button) and right click (there is an arrow there to indicate that).
After that you can scroll with the up/down arrows through the list to the station, you want to listen to – then press ‘Go’ (the big button in the middle).MM
9 April 2023 at 11:03 #45624Vedet
BRONZE MemberThank you for such a detailed, clear and informative answer. This helped me a lot, since none of the instructions reflect this. I congratulate you and your loved ones on the Bright Resurrection of Christ – Easter.
9 April 2023 at 11:18 #45625 MillemisBRONZE MemberThere you go ?
