Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote One: can you see which source is playing?
- This topic has 4 replies, 2 voices, and was last updated 3 years, 1 month ago by
jjcox.
28 January 2023 at 08:59 #43377
jjcox
BRONZE MemberHi!
I just received a Beoremote One BT finally control my BS Core without the phone. I actually thought the BR One was a two-way system, meaning that you could see which source was currently playing.
Maybe I’m mistaken, or is it just a setting I have wrong? (because I can’t see it.)
Thanks!
28 January 2023 at 23:51 #43378 MillemisBRONZE MemberNo, it is not 2-way in that sense.
However, it receives the information from your Core, how this is setup….you might say it is then taylor made for the Core.
As an example, you can see the favourites you have made for the B&O Radio and choose a specific station from the list.MM
28 January 2023 at 23:54 #43379jjcox
BRONZE MemberAh, thank you :-).
Indeed, I do see the radio stations and that makes it two-way.
Which brings me to a second question: AFAIK there is no way to change the order of the radio stations in the app (and thus in the BR One), except for removing the stations from the favourites and add them again in the desired sequence.
Or is there a way? It seems such basic functionality.
29 January 2023 at 00:03 #43380 MillemisBRONZE MemberNo, unfortunately not……..yet!
This was discussed here some time ago and also reported to the support.
As of now it is a pia to ‘reorder’ your stations or add a new station to a specific place in the list.
We must hope that they get this sorted out soon.MM
29 January 2023 at 00:09 #43381jjcox
BRONZE MemberAh, thank you very much for clearing all this up MM!
Appreciated.
