Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote one buttons falling off
- This topic has 5 replies, 4 voices, and was last updated 2 hours, 26 minutes ago by
Stan.
18 January 2024 at 01:07 #52255
IA64
BRONZE MemberHello guys, my Beovision TV was hardly used and has been idle for almost 2 years as I’m mostly travelling for work.
Today, I turned on the TV and started navigating the menu when suddenly the arrows button fall off… I tried to put it back in place but it keeps coming off. Then the volume +- button also fell then the buttons surrounding the arrows fell as well .
I have no idea what’s going on but the remote is like new, hardly used maybe 3-4 times and that’s it.
Anybody knows what’s going on?
18 January 2024 at 17:01 #52256 hiortGOLD MemberNever experienced….
Dont think you can fix that. You can buy the “electronics part” of the remote as a separate item from B&O. Then you can keep the metal part.
18 January 2024 at 17:03 #52257 hiortGOLD MemberThink price is around 180 euro.
19 January 2024 at 15:58 #52258IA64
BRONZE MemberOK but what’s holding the key in its place? I must be missing something because yesterday the arrow and volume key weren’t attaching to the remote but now i have almost all the lower part that isn’t attaching anymore.
Once a key is out there’s no way it will attach to the remote again which is very unusual for such an expensive unit.
20 January 2024 at 02:42 #52259svendsen991
BRONZE MemberIt should be attached with some pretty strong adhesive if I remember correctly.
I never experienced it as well.
Was the remote stored/placed directly in the sun or got exposed to high temperatures in some way?10 January 2026 at 23:38 #72484Stan
BRONZE MemberI am having this same problem. My “play” key falls off. Has anyone tried gluing a key back on?
I’m thinking of some carefully applied superglue. It looks like the internal mechanical button has a plastic “shroud” that has some glue residue so maybe it is just that simple?
Stan
