Home › Forums › Product Discussion & Questions › BeoRemote › Beoremote One BT Sony TV Pairing
- This topic has 4 replies, 4 voices, and was last updated 2 years, 5 months ago by
haninehme.
31 October 2023 at 07:52 #50023
haninehme
BRONZE MemberHello,
Just bought a Beoremote One BT that I am trying to pair using BT to a Sony Bravia TV (KD-65X9000E) , set remote for pairing, and TV into Bluetooth pairing mode, TV says searching for accessories, and nothing comes up – any idea how to fix this??
1 November 2023 at 22:11 #50024 kuyttendaeleMemberI wasn’t aware that the BeoRemote was Sony compatible.
The only TV that out of the box (and after installing an app on the TV) work are the LG Oled screens.I might be wrong but I don’t think that your TV will work with the remote… Kinda like saying you downloaded the latest Apple OS and want to install it on your Windows PC.
Karel.
2 November 2023 at 14:17 #50025Steph
BRONZE MemberI agree with Karel, I think Sony TV are not compatible with B&O remote(s), even the BT one.
P. S. : Hey Karel, are you still satisfied with your BV 14 and your Balance?3 November 2023 at 12:46 #50026Anonymous
InactiveWhy do you think this will work?
beoremote one bt si for b&o tv and LG (only with
stage,eclipse,harmony,theatre) because the beoremote one comunicate with the beopart that with hdmi and lan comunicate with LG screen
4 November 2023 at 20:31 #50027haninehme
BRONZE MemberThanks everyone for your update, for some reason I had thought Beoremote One BT will work with Sony the same way as LG.
In any case, I have paired with my Apple TV using BT for now – only issue is when changing products to another BT connection such as Beoplay A9, I have to reconnect the Apple TV again by going into the Apple TV bluetooth menu, any way of reconnecting the remote to Apple TV without doing that?
