Home › Forums › Product Discussion & Questions › BeoRemote › BeoRemote one BT and LG C4 65 via Beosound Stage – TV Won’t switch on
- This topic has 5 replies, 3 voices, and was last updated 13 hours, 17 minutes ago by TinusAMS.
9 January 2025 at 10:35 #62437
I finally decided to swap out my 7 year old Samsung with a new LG C4 65″ as I already have a Beosound Stage from before.
So I also added a BeoRemote One BT (BR1) as well as a Floor Stand 4547 (Beostand Stage) to complete the setup.
All connected up fine (had to reset the stage to get the BR1 to accept the Stage) and all functions work as they should (including controlling the Amazon Firestik 4K Max connected in HDMI1) which is great.
Only problem is that I cannot seem to switch on the TV with the BR1, the Stage 2 diodes lights up, but not the TV – it stay’s off.
Switching off is no problem.
I looked through the online guides on B&Os web site (stage) but doesn’t give any instructions and seems to be based on older WebOS LG setups.
Any pointers, as this is so frustrating… Last 1% to reach the perfect setup, making up 99% annoyance.
31 January 2025 at 13:30 #63254Quick Update and follow up question(s)…
For some strange reason it started working, meaning I could switch on the Stage and TV with the Beoremote, but then all of a sudden it stopped, and back to square one.
When I press “TV” on the BeoRemote One BT, the Beosound Stage turns on (two white lights) but the TV remains off. I use the LG remote to switch on the TV, and all the TV functions work as expected with the B&O remote, and same when I go to switch off the system.
I have not the faintest why the only function (Turn system on) doesn’t work when everything else does (and that it did work for 2 weeks or so)….
Just to make sure Im not doing anything wrong: What should the screen on the Remote show before I can switch TV and the Soundbar on by pressing TV? I have tried multiple (HDMI 1, Live TV, SIPTV App etc etc), or is there another sequence of buttons I should press before the signal is read correctly by the Beosound Stage and LG C4 TV?
1 February 2025 at 06:48 #63279After pressing tv, choose source, and press ok.
Otherwise try other cables between tv and Stage.
The BR1’s signal travel thru the cable to the tv.Location: Netherlands1 February 2025 at 13:24 #63287“After pressing tv, choose source, and press ok…”
THANK YOU so much Captain… Did just what you recommended and it’s now working again.
Drinks are on me next time
1 February 2025 at 18:10 #63297🍻
Location: Netherlands4 February 2025 at 19:28 #63410I don’t have a Stage, but with Theatre you can also change the button to directly go to the source (instead of scrolling and pressing ok, just one push on the tv button and everything switches on).
With Theatre it’s under Settings > Sources > Tv sources > Source from stand-by
My B&O Icons: -
