Home › Forums › General Discussion & Questions › General Discussion & Questions › BeoRadio M3 (not loading)
- This topic has 5 replies, 3 voices, and was last updated 1 year, 4 months ago by
L1no.
7 November 2024 at 20:02 #60759
L1no
BRONZE MemberSince a week or so my beoOne remote does not show radio stations and my M3 does not play any station through the app. Recently there was a update concerning Radio.
Any suggestions? (did a Factory Reset) Any other products?
The V1, Core, Theatre or BeoConnect work fine as any other feature of the M3.8 November 2024 at 12:45 #60767 HiortGOLD MemberJust tested my M3. No such problems.
8 November 2024 at 13:56 #60768 MillemisBRONZE MemberAlso none here.
10 November 2024 at 07:53 #60805L1no
BRONZE MemberThe M3 gives the following messages under critical events, “Unable to register with BeoPortal“.
Anything i can do?
10 November 2024 at 11:24 #60808 HiortGOLD MemberCan you somehow make sure that the M3 is connected to Internet? Not being able to access Beoportal points in that direction…
18 November 2024 at 23:16 #61040L1no
BRONZE MemberFound out that factory reset through the app is NOT the same by using a on-device method. With a recent update some devices showed a this behavior of not connecting. Using the device it’s reset button did the trick.
