Home › Forums › Product Discussion & Questions › BeoLab › BeoPlay V1 40 speaker connections
- This topic has 1 reply, 2 voices, and was last updated 8 months, 3 weeks ago by
Peter Fraser.
28 June 2025 at 19:47 #66714
mpc1507
BRONZE MemberI have a Beoplay v1 40 and I need to connect my Beolab 2 sub and 4 Beolab 4000,s . i need guidance on cable routes and set up please if anyone can help. many thanks
30 June 2025 at 10:03 #66733Peter Fraser
ModeratorHello,
You can find the user guide for the Beoplay V1 television here:
Beoplay V1 – Bang & Olufsen SupportThe guide explains how to add speakers and complete the setup—please refer to pages 9 and 19 for relevant instructions.
To connect external speakers, you will need a Powerlink to RJ45 adapter or a pre-made cable.
DIN Female to RJ45 – Part Number: 6271237These items may be available from your local Bang & Olufsen store or service centre.
Bang & Olufsen Store Finder – Find the nearest locationIf you prefer custom cables, I recommend contacting Sounds Heavenly:
https://soundsheavenly.com/Kind regards,
PeteSignature: Peter Fraser
Service Technician
Multicare Electronics -
