Home › Forums › Product Discussion & Questions › BeoPlay › Beoplay A9 (5th GEN) and Sonos Port
- This topic has 1 reply, 2 voices, and was last updated 1 year, 11 months ago by
trackbeo.
11 April 2024 at 02:06 #54216
BinniB
BRONZE MemberHi guys,
I have a “problem”Have Beoplay A9 (5th GEN) and Sonos Port connected to it via ( RCA to USB-C A9 G5 does only have USB-C (dongle included))
However I can not get the get the volume “up and down” to work correctly.
I can pick line in on A9, but I can not control volume through Sonos app The volume is stuck at predefined level and I need to open up the B&O app to change the Volume!
Is there a workaround? Running: 3.4.1( software on A9)I have a transmitter1 + pair of beoplay 17 and sonos port connected to transmitter 1 via Rca and that is fine
With hope of help
BWMr.B
11 April 2024 at 18:15 #54217 trackbeo
BRONZE MemberIn the Sonos app, the Settings tab, tap System.
Select the room with your Port, then tap Line-Out Levels and choose “Variable” instead of “Fixed” or “Pass-Thru” (you wish, be serious). -
