Home › Forums › General Discussion & Questions › General Discussion & Questions › BeoMaster5/BeoSound5 beoconnect problem
- This topic has 3 replies, 4 voices, and was last updated 7 months ago by
NQVHNWI.
25 March 2024 at 10:33 #53819
Paolo
BRONZE MemberHi, I have a Beomaster/Beosound 5 system and i’ve tried to Connect it to my pc. I installed beoconnect and the first time it went and Connected and I could see the share hdd. Then after 5-10 minutes it does no longer let me transfer the songs to the beomaster 5, and at that point I saw that there was a red (X) on the HDD icon and it gave me an error saying “unable to connect to…”. then I restarted the beomaster and I realized that the IP address was no longer the same as before but had changed, now completely different from that of my PC (previously only the final digit changed). I also tried disconnecting and reconnecting the LAN cable (cat 6 and connected directly to the router in the classic output, not WLAN) but nothing worked.
23 May 2024 at 12:28 #55913hackel
BRONZE Memberhi, you’ll have to put a static IP adress for the Beomaster. To do this, you’ll have to go to the service menu and in the Windows parameters.
If you need more help, I’ll can do it again on mine, adn tell you the step. I’ll did it more than 10 years ago !
24 August 2025 at 16:09 #69079Joris Allewijn
BRONZE MemberHi, could you perhaps tell me how I can reach the service menu on the Beomaster?
Thank you in advance.
Joris
Favourite Product: Beosound 5
26 August 2025 at 13:07 #69100
NQVHNWIBRONZE MemberMove the navigator arm to MODE and use the wheel to highlight SETTINGS. - On BeoSound 5, press: >>, <<, >>, <<, GO to activate ‘Service Configuration Menu’
