Home Forums Product Discussion & Questions BeoMaster Beomaster4000 dying channel
  • #74433
    alf
    SILVER Member
    hi everyone,
    my BM4000 has developed a channel drop out issue.
    its starts quite normal but after 5 to 15? min the left channel just disappears.
    i checked the corresponding output transistors but they are fine, checked the emitter resistors which drifted
    by about 25%, so I fitted a replacement set – the strange thingis that the original emitter resistors were
    specified as 0.33 ohm resistors, contrary to the service manual which says 0.15 ohm ??
    anyhow, can someone point me in the right direction here – that would really help.
    I wonder if there is a hidden switch issue as the cause, it looks like a heat problem to me amongst
    various other options ??
    thank you for helping out
    ALF
    #74537
    hcraig244
    SILVER Member
    New one on me…..not came across this before, does sound like a overheating issue….possibly breakdown of the compound applied to the output transistors on the offending channel not providing a good transfer of heat to the main heatsink? I will look forward to the conclusion of this one ;¬)
    Craig
