Home › Forums › BeoWorld around the world! › Nordic › Beomaster 7000 sound in front jack only
- This topic has 7 replies, 2 voices, and was last updated 1 month, 2 weeks ago by
skolesen.
4 February 2026 at 17:40 #73219
lenhi
BRONZE MemberYes, I still have this machine driving me crazy, after two tours to a tech. Came back home, plugged it in, and the Powerlink to the speakers does not work.
I set the OPTIONS to A1 and V0, and the SPEAKER to 1, though the display on the Beomaster does not respond to that.
Having gone through a test session guided by AI, the recommendation was to get a new Omron G2R-2-SN (DC24) relay.
I would much appreciate any input on this. Have I got the settings right? Are there any additional tests I should do? The oputput is fiine; it just does not get to the Pentas.
5 February 2026 at 15:40 #73263 skolesenGOLD MemberI would check that the muting pin in the jack plug isn’t permantly connected to GND.
I’ve seen that before./steffen
9 February 2026 at 19:52 #73463lenhi
BRONZE MemberThank you for your advice, steffen, but although I have tested the audio jack on the left side of the front, and have perfect sound when connecting a headset, I do not know what or where the muting pin is.
10 February 2026 at 21:11 #73506 skolesenGOLD MemberHave you tried to connect normal speakers to SPEAKER 2 output?
18 February 2026 at 12:10 #73955lenhi
BRONZE MemberYes, skolesen, I did, and they work, after I touch the volume on Beo4. I had the Beomaster 7000 checked, and it turns out there was a glitch in the audio jack. The Pentas still do not work.
18 February 2026 at 17:17 #73988 skolesenGOLD MemberNormally if there is only audio in headphone jacket and SPEAKER 2, these can be there reasons:
- a bad mute relay (RL1)
- bad TR2
- the mute pin in the haeadphone jack is constant set to GND.
Next question: Is there audio in SPEAKER 1?
If yes, is there 12V on PL pin 3 (PL ON/OFF) when the BM is on?
If no check TR5 on the power supply.
If yes, then check the PL cables.
/steffen
18 February 2026 at 17:35 #73990lenhi
BRONZE MemberYes, there is audio in Speaker 1 (passive speakers) when I connect the 4500.
I am learning here; 12V on PL pin 3 must mean the powerlink pins, so I will check that, but which powerlink are we talking about? The PL on the BM is not in use.
TR5? What is that?
18 February 2026 at 17:49 #73993 skolesenGOLD MemberYou have started the same topic in two different forums at the same time on Beoworld without explaining your setup i the Nodic forum.
I thought that your Beomaster 7000 was in a “solo” setup and not a part of a multi room.
So I can’t help you there.
/steffen
