Home › Forums › Product Discussion & Questions › BeoMaster › SOLVED !! Beomaster 7000 has suddenly become very silent
- This topic has 7 replies, 4 voices, and was last updated 6 months, 1 week ago by
nitro2.
23 August 2025 at 11:51 #69035
nitro2
BRONZE MemberHi forum ,
One of my beomasters 7000 became very silent last week ,
no sound from the attached cx50 speakers , and no sound from the beolab penta’s ( connected via powerlink cables )
the bemaster 7000 powers up , i can use the 1000 remote to go through the functions , sources , tracks , and i can change the volume BUT the output is 100 % silent on all outputs .
Anyone who can shine a light on this
23 August 2025 at 12:51 #69039 CharlieWednesdayGOLD MemberHave you tried plugging your CX50s into the Speakers 2 outputs instead of Speakers 1? Let us know if they work that way.
23 August 2025 at 13:15 #69040nitro2
BRONZE Memberno output at all .
so pcb 7 is not the cause ( i think )
both right and left is missing on every output
23 August 2025 at 19:29 #69056 lausviSILVER MemberAnything on the headphone out?
Is the white dummy-plug present at the Beomaster’s LINE IN/OUT connector (below the speaker 1 connectors)?
23 August 2025 at 21:11 #69058nitro2
BRONZE MemberYes , that plug is present .
Strange thing it stopped suddenly without a plop , only silence on all 4 outputs .
i noticed there is no “pop”sound when i switch on the master , so it looks the whole amplifier section is not working .
Mute relay is working .
Is there a fuse for the power-amp section ?
30 August 2025 at 07:31 #69208Dillen
ModeratorIs the 8V present for the tonecontrol circuits?
If not, check 3TR4 (BC547B) and all filter capacitors related to the supply voltages in the preamplifier.Martin
1 September 2025 at 19:18 #69292nitro2
BRONZE Memberlooks like the relay rl1 is acting a bit strange ,
only has an active break-contact , i don’t know if that is supposed to be that way as the schematic indicates it should be closed active via tr19 .
am i missing something here ??
7 September 2025 at 08:33 #69443nitro2
BRONZE MemberAs adviced bij Dillen ,
replacing the relay after 30 years is a good idea as the contacts have detoriated a lot !
this is clearly visible in the metal “coating” on the inside of the plastic housing .
= the real problem however turned out to be TR19 , after replacing the bc337 the relay responded to the standby signal again ( as is was shorted to mass , the relay was active all the time ) .
Thanks Martin for assisting !!
You must be logged in to view attached files. -
