Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 7000 front panel (sometimes) not working
- This topic has 2 replies, 2 voices, and was last updated 2 years, 11 months ago by
Die_Bogener.
31 March 2023 at 02:08 #45131
filip_kbhBRONZE MemberMy Beomaster 7000 has begun to display a strange behaviour. After some time on standby, the left button will not turn the unit on again. If I then use a remote control to turn it on and then off, the front panel button wil work again. However, after some time – e.g. if I want to turn it on next morning, the button will not work again. Argh.
I initially thought it was the backup battery that needed replacement, so I did that. Same result.
Can anyone point me in a direction to what I should look for?
Of course I can just use the remote but it annoys me that the Beomaster is not working 100% as it should.
10 April 2023 at 12:27 #45132 filip_kbhBRONZE MemberStrange – it seems that the problem fixed itself. Now it works every time.
10 April 2023 at 18:04 #45133Die_Bogener
BRONZE MemberThe switches can have oxidation. There ist just a switch going to the 8155 port chip, nothing elase but a cap an d a resistor.
The switch itself can have a problem. You can measure it, resistor 0 or very high.
But what helps: replacement or some current around 200-500mA… the current will clean it. But only if disassembled or the cpu will die.
Second possibility: there is a connector from the front pcb to the cpu board. The connector can have the same oxidation, but can be cleaned.
