Home › Forums › Product Discussion & Questions › BeoMaster › Beocentre 7000 cassette belts
- This topic has 3 replies, 2 voices, and was last updated 3 years, 7 months ago by
Hosky57.
17 August 2022 at 06:21 #37060
Hosky57
BRONZE MemberHi Guys
After opening up the Beocentre 7000 does one have to remove the cassette mechanism to clean and change the belts or is this with it done in situ but unscrewed?
If it needs to come out how do I get access under the record deck to unplug the wiring loom please?
19 August 2022 at 14:54 #37061Hosky57
BRONZE MemberI’ve sorted this thanks. I discovered that the record deck also lifts up from the rear which allows the cassette looms to be unplugged and thence the cassette deck removed for servicing.
19 August 2022 at 15:13 #37062Dillen
ModeratorSounds like a Beocenter 7000 rather than a Beomaster 7000.
19 August 2022 at 15:55 #37063Hosky57
BRONZE MemberYes very sorry Dillen it is the Beocentre 7000 as you say
