Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 7000
- This topic has 1 reply, 2 voices, and was last updated 2 years, 2 months ago by
Tignum.
8 January 2024 at 08:49 #52026
jameswmunson
BRONZE MemberBeomaster 7000
Hi all sorry in advance as I know this must have been asked a thousand times but I still can’t (after about 3 years) get this to work. I currently set the bass loudness etc each time I turn the system on. I know there must be a way to store this so it’s there each time I turn it on. I have the beo 4 remote (and the beolink. 1000 but that’s for show). I’ve done the list > a setup > the bass loudness etc > the s store > ok but it never stores it should I get a message to say it’s stored? Each time I do this it’s never keeps the setting when I turn it back on – and can you set the turn on volume as currently it blasts out if you forget and don’t have the remote near by! Many thanks!
8 January 2024 at 21:49 #52027 TignumGOLD MemberHi jameswmunson, could it be that the back-up battery is dead?
Besides that, I do recall some BMs needed the STORE command to be made twice before keeping the settings. Maybe worth a try.
When the storing of the sound setting works, it will also store the volume setting at the time of storing.
Regards, Johan
