Home Forums Product Discussion & Questions BeoMaster Beomaster 6500 repair – internal fuses?
  • #68908
    CharlieWednesday
    GOLD Member
    My most recent acquisition (as I continue to suffer from incurable Beovirus) is a full Beosystem 6500 in white, which includes the MCP6500.  It is in excellent cosmetic condition but was obtained at a good price because it’s not fully working.
    Beogram and Beogram CD both seem fine, although tested only briefly so far. Beocord will need new belts (makes a noise but will not play or wind), but I’ve met that challenge before and fixed a few B&O tape decks, including a 5500, which I know is very similar to the 6500.
    The main problem is the Beomaster, which gets no power.  I am no electronics expert but I opened it up, and found a fuse next to the power supply; hidden beneath a paper flap thingy and I can see a fuse labelled ‘T2A’.  I tested it with a voltage screwdriver, and I’m only getting power at one end.  I removed it and could then see it had clearly blown.  Could be an easy fix!
    However, I checked the service manual and I think I can find the above fuse given as F1T2A on the circuit diagram, but I also see another fuse on the diagram labelled F1T5A, and I cannot find it!  I figure I might as well test that one too, but I don’t know where it is!  If anyone happens to know it’s location, please let me know.
    I know there’ll be a reason the T2A fuse blew and it might not be a simple fix, but I might as well start there.
    My B&O Icons: No description available No description available No description availableNo description availableNo description availableNo description availableNo description available No description available No description available No description availableNo description availableNo description available
    #69209
    Dillen
    The other fuse lives at the back right side, on the board way down in the corner.
    • This reply was modified 3 weeks ago by Dillen.
    #69212
    CharlieWednesday
    GOLD Member
    I didn’t find that, but as it turned out I didn’t have to – when I replaced the T2A fuse, I got power back! It’s been working since.  I’m about to go on holiday but when I’m back, I’ll replace the belts in the Beocord, then my Beosystem 6500 will be in full working order.
    Thanks for the answer anyway – you never know, I may need it some day.
    #69788
    CharlieWednesday
    GOLD Member
    Update – 3 weeks have passed with my Beomaster 6500 working fine, but now the same fuse (T2A) has blown again.  I am assuming therefore that there is some other underlying cause.
    I have replaced it again and it’s working again, but I’ll have to monitor it.
    If anyone happens to know what the cause might be please let me know, but otherwise if that same fuse blows again, I think I’ll have to get a professional in to look it over.  John from Merlin AV has never let me down so far, so it may be another one for John.
    #69789
    CharlieWednesday
    GOLD Member
    …it only worked for a few minutes, then there was a puff of smoke out of the back and it failed again.  The fuse has gone again, I also noticed that there is a pair of cylindrical things (capacitors, I assume) at the back behind the transformer, and one of those (only one of them though) was very hot to the touch.  That is in the area where the smoke was coming from.
    I think this definitely will be a job for John!  I’ve emailed him for a quote, as he’s due to drop some other repairs back to me on Monday so might as well pick the BM6500 up then.
