Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 6500 lower side panel
- This topic has 0 replies, 1 voice, and was last updated 3 years, 1 month ago by
Giorgione.
Viewing 1 post (of 1 total)
2 February 2023 at 11:41 #43494
Giorgione
BRONZE MemberThe lower side panels of my white Beomaster 6500 are partly coming loose. What’s the recommended method to remove them completely in order to glue them on properly again? Iron above a soft cloth? Whilst the lower body of my BM5500 seems made of metal (knock test), the one of the 6500 seems a chipboard. Is that possible? Ok, I can only see some 2 cm of it…
I will try to make some pictures tomorrow, if needed.
Thanks!
ccMy B&O Icons:
