Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 6000 quad – worth repairing?
- This topic has 17 replies, 3 voices, and was last updated 2 years ago by
notwist.
20 February 2024 at 12:59 #52923
notwist
BRONZE MemberHi all,
I don’t post often anymore as I’ve developed an illness that leaves me visually impaired. I am no longer able to repair equipment.T
hat said, I was gifted a complete set of time Beomaster 6000 4-channel receiver. With deck, record player and remote.
Sadly the beomaster is very dead. It does power on, I can hear the transformer. A red light is showing. But that’s it. Doesn’t respond to anything.
I am wondering if repairing is feasible. And if anyone knows a b&o specialist in the Netherlands.
Kind regards,
Bert
22 February 2024 at 13:48 #52924hcraig244
SILVER Memberthese amps are certainly worthy of repair/restoration, they are a marvel of engineering…I believe hendrik from the site here lives on your part of the world, he has provided me with bits and pieces for 6000 quads in the past, he may be the one to help you….Im in the UK so not a lot of help I’m afraid
22 February 2024 at 14:12 #52925notwist
BRONZE MemberThanks!
I hope I can find him through the search engine.
Machine still looks good, would be a shame if it wasn’t restored.
Regards,
Bert
23 February 2024 at 19:52 #52926notwist
BRONZE MemberSadly I can’t find Hendrik using the search engine. Does anyone know his username?
Regards,
Bert
25 February 2024 at 09:36 #52927 square4BRONZE MemberTry to search Henrik instead or username square4 ?
Henrik.
25 February 2024 at 10:38 #52928hcraig244
SILVER Memberhehe…..sorry Henrik, my fault….how are doing anyway? all good……..
Craig
25 February 2024 at 14:39 #52929notwist
BRONZE MemberHey Henrik,
Nice to meet you here. Sorry for the mixup ?.
Perhaps we could speak about restoring the Beo 6000. It shows no response after powering it up. Just a red light. I’m unsure if this is a standby light or the IR light.
It would be a shame to scrap it. Because I have suddenly become nearly blind I’m not able to do anything with it anymore.
Many thanks for your time!
Kind regards,
Bert
26 February 2024 at 13:45 #52930 square4BRONZE MemberHi Craig.
Yes, besides getting old i am alright,sort of.
How about you?
Hi Bert.
I am not an repair man,i only have some spare parts for these wonderful receivers, but most of them are sold now.
Do you have the remote control for the 6000,and if you have can you get anything working by using it?
Under the control panel there are glued some plastic parts,and if they are falling of you can’t use the control panel
That is my best guess, sorry i can not help any further,but as Craig said they are absolutely worth getting repaired.
Henrik.
26 February 2024 at 14:15 #52931hcraig244
SILVER MemberHi Henrik..
Pretty much like yourself. the clock is ticking as some say…but overall I’m still in good shape for an old man ;¬)
Bert…could be your 6000 is stuck in standby, very difficult to diagnose without eyes on, and if yours are failing it wouldnt be easy for you to open her up and do some tests…but do replace the remote battery and give that a go…maybe someone closer to you will weigh in and volunteer some assistance, the UK is a long way to send such a heavy amplifier ;¬)
Craig
26 February 2024 at 15:53 #52932notwist
No problem and all insights are very much welcome. I am relate to feeling the clock ticking.
I put the machine in service mode. And removed the aluminium front. I’ve done this kind of work so often I can literally do this blind.
My spare eyes (read: wife) says there is nothing strange to see. No blown components and very clean.
I think the red light might be the infrared sensor, but guessing here. I do have the remote the set is complete.
Problem with the remote is that it needs a 15v battery. In some special format. For the love of me, I can’t find it for anything resembling a reasonable price. I think I would pay €30 for one.
But will search further because it is a good idea. I had a beo that also had a stuck it receiver that didn’t respond to anything.
Regards,
Bert
26 February 2024 at 16:21 #52933 square4BRONZE Member26 February 2024 at 16:27 #52934notwist
BRONZE MemberOK check. It is another type but I guess it will work all the same. Will take some time to get to me, can’t give an update within a week or so.
Regards, Bert
27 February 2024 at 09:16 #52935hcraig244
SILVER MemberBear in mind that the Commander uses ultrasonic not infrared…….have a listen and see if you can hear the standby relay operating when you first switch the mains power on……I have had issues in the past with a standby relay which although was operating its contacts where not making/breaking. The standby relay allows power to all functions however if your amp has been unused for a long time some of the lamps may have failed despite power being available, so may give a false impression that nothing is getting power…
27 February 2024 at 16:24 #52936notwist
BRONZE MemberOkay I checked this. For sure when I power the Beo there is no relay click. I can hear the transformer and there is a red light. But no relay. Hnnnnm.
27 February 2024 at 18:36 #52937hcraig244
SILVER MemberOk
Just had a look at my BM6000 units, I have two of them…….both do the same thing. When i power up from the switch at the back I cant actually hear the standby relay energising/clicking……the red lamp is illuminated. Pressing standby puts power to the tuning strength meter and also to the control position indicators, all function switches operate as normal…FM switch lights tuning indicator slider. pressing the standby switch gives an audible click as the relay de energises and all lamps go off except the red standby lamp….pressing standby switch again gives an audible click as the relay energises and power is restored……
dont know if this helps
28 February 2024 at 09:33 #52938notwist
BRONZE MemberThis information is superbe to clarify expected behavior as it does differ from other beomasters.
Mine doesn’t do anything, it just sits there glaring at me with it’s beady red eye. It doesn’t respond to pressing the standby button.
The only thing I could think of is that literally all lamps are dead. So you wouldn’t know if it did spring to life. But that is really far fetched. That said, certain lamps be crucial to the operation, I just don’t dare to put a multimeter in there. With my eyesight it’s really easy to mess up.
Let’s wait and see what the battery for the commander does.
Regards,
Bert
28 February 2024 at 16:09 #52939notwist
BRONZE MemberI was able to procure a compatible battery from a Dutch supplier. It should be here much faster, maybe I can test it tomorrow.
Regards, Bert
29 February 2024 at 18:03 #52940notwist
BRONZE MemberOK battery has arrived. Put it in the remote control. Sadly no change. I was able to find someone with experience on the Beo quad. I will let him work on it.
He can work on it around September this year so let the wait begin. Really curious as to what the problem is.
Regards, Bert
