Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 6000 4channel Lamp Replacement
Tagged: BeoMaster, beomaster 6000 4channel, Help, Repair
- This topic has 3 replies, 2 voices, and was last updated 8 hours, 2 minutes ago by
hcraig244.
11 June 2025 at 05:42 #66283
Megan Henderson
SILVER MemberHey everyone! I’m working on cleaning up a beomaster 6000 4channel and if got everything working but I can’t seem to figure out how to change the bulbs. I know I have to solder them in there but I can’t seem to figure out how to get to them. This is where I’m at currently and I got a bulb kit from danish sound parts. Please help!
You must be logged in to view attached files.11 June 2025 at 06:14 #66285hcraig244
SILVER MemberHi
Are you changing out all the lamps on the machine or just those that have failed? Some lamps are fitted into an enclosed plastic compartment, others are not. You will need to open the unit up to access all lamps…..check out the service manual available here for a better idea, be sure to replace the lamps according to the description provided by the supplier, the current ratings differ from location to location…….enjoy 👍
11 June 2025 at 14:16 #66294Megan Henderson
SILVER MemberHi
Well I was planning to do all of them since I was already in there but I should probably just stick to the ones that failed for now! Attaching a photo of the ones I know need swapping out. I can see the bulbs and I have the correct ones ready to replace I just have no idea how to get fo them because they are in little plastic casings
You must be logged in to view attached files.12 June 2025 at 06:20 #66317hcraig244
SILVER MemberOk
you will need to lift the indicator ribbon display section up into the vertical position to access the lamps….2 screws as I recall, these lamps are connected in three series loops I think…so if one goes down you loose 2 or 3 lamps….its been a couple of years since I changed any. As a silver member you can access the service manual for this machine under products in here, this details how to open it up…..unfortunately im windsurfing off the coast of Greece until Sunday….if no one chips in with more help I will open a machine up and send some pictures to guide you next Monday when I return to the UK
Craig
