Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5500 running hot
- This topic has 4 replies, 4 voices, and was last updated 2 years, 10 months ago by
chartz.
15 May 2023 at 09:08 #46624
Beosuomi
BRONZE MemberI have a Beomaster 5500. Does everything it’s supposed to, but it’s quite hot. The heatsinks are burning up, but the system itself doesn’t shut down or restart. Is this normal?
15 May 2023 at 14:17 #46625Die_Bogener
BRONZE MemberIt is not normal.
There are 2 potentiometer on the amplifier section, adjusting the “no-load-current”.
Replace the pots (100 Ohms?) and look for this adjustment. 11mV across TP200-201 and TP400-401.
15 May 2023 at 17:22 #46626Beosuomi
BRONZE MemberIt is not normal. There are 2 potentiometer on the amplifier section, adjusting the “no-load-current”. Replace the pots (100 Ohms?) and look for this adjustment. 11mV across TP200-201 and TP400-401.
is there a tutorial somewhere?
15 May 2023 at 17:35 #46627 matadorModeratorYou’ve got the answers, you’ve got the schematics, you’ve got the value, that’s all the tutorial you’ll need.
Hello, please and thank you would have been welcome also.Location: Paris France
15 May 2023 at 21:13 #46628 chartzBRONZE MemberHi,
And then news when the (easy) repair is done!
Best wishes,
Jacques
