Home › Forums › General Discussion & Questions › General Discussion & Questions › BeoMaster 5000 voltage conversion to 120v
- This topic has 4 replies, 2 voices, and was last updated 1 year, 8 months ago by
Gene Ku.
3 July 2024 at 01:06 #57155
Gene Ku
BRONZE MemberGreetings,
Looking for help: Wanting to convert a 220v BeoMaster 5000 to 120v. I found the wiring schematic but it doesn’t say what type thermal protection (maybe R40) nor how to mount it. Maybe someone has one or has done this? Also, curious if a fan might be better (saw a post about that).
Thoughts?
Thanks for your reply.
Gene
You must be logged in to view attached files.3 July 2024 at 06:27 #57165Dillen
ModeratorR40 is the NTC resistor for the over-temp protection circuit in the amplifier section.
It has nothing to do with the wiring of the mains transformer.The mains transformers shown on page 8-4 for 100V and 120V are different from the one used for 110/130/220/240V.
Seeing as you have a Beomaster currently set for 220V:
If you have 110V in your mains, I would convert to that.
If you have 120V mains I would convert to 130V.
If you absolutely must convert to 120V you must replace the transformer with a correct one (8013299, that has a thermal fuse built-in).You must also replace the mains fuse with one of twice the amp rating. (Half voltage – twice current – same power, also known as Ohms law).
3 July 2024 at 06:43 #57168Gene Ku
BRONZE MemberMany thanks, Martin!
I have 110v but have seen it go to 115v which is why I was thinking 120v–probably too much thinking and not worth changing the transformer.
Thanks for the reminder about the fuse!
Regards,
Gene
3 July 2024 at 12:18 #57169Dillen
ModeratorI wouldn’t worry as long as we are within +/-10%.
I don’t think the power plants can guarantee a tighter tolerance anyways.Martin
6 July 2024 at 04:47 #57237Gene Ku
BRONZE MemberThanks again!
