Home Forums General Discussion & Questions General Discussion & Questions beomaster 5000 turns on with volume at maximum
  • #62937
    gpv
    I ask for help. My beomaster 5000 turns on with the volume at maximum, I changed the battery and the diode seems good but if I memorize when I turn it on again the audio is always at maximum
    #62938
    billb
    GOLD Member
    Just to check the obvious, are you using the MCP5000 to memorize?  When you have chosen the desire volume did you press “Store”, and then when a “P” blinks did you press “Sound”?
    #62971
    Dillen
    Also – replace capacitors in the processor module.
