Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5000 power problem
- This topic has 4 replies, 2 voices, and was last updated 2 years, 8 months ago by
gpv.
10 July 2023 at 08:58 #47587
gpv
BRONZE MemberHi, I have a beomaster 5000 with a blown fuse, I replaced the battery, all the capacitors on the power amplifier board and the preamplifier board. Now when I turn it on the two relays trip but the red light doesn’t work, if I press the button it turns on then you see the word loudness which fades away. Can anyone help me? what could i check?
12 July 2023 at 21:30 #47588gpv
BRONZE MemberCan anyone help me?
13 July 2023 at 09:29 #47589gpv
BRONZE MemberHi everyone, I’ve partially solved it, there’s only one problem left.
When I plug it in it doesn’t turn on but when I press a button on the control faceplate it turns on and then it works.
When I unplug it and put it back the problem reappears….????
Please does anyone know the problem? And do you know what I could check to fix the problem?
Thank you.22 July 2023 at 08:56 #47590Audionerd87
BRONZE MemberHave you double checked the connections to the processor board (one by one) at the front of the unit. If it is actually turning on (which is a good sign, didn’t fry the CPU ) it may be a connection issue seeing as the cables and corresponding plugs are pushing 40 years old. Additionally, you may want to look at the internal IR sensor. They can cause a host of unusual problems when they start to go bad.
22 July 2023 at 20:48 #47591gpv
BRONZE MemberI have another one that works and I tried to replace the processor board but the problem remained, then I also changed the display capacitors but the problem remained.
The relay works but maybe I should replace it anyway just to be safe? -
