Home › Forums › General Discussion & Questions › General Discussion & Questions › Beomaster 5: Networkinfo
- This topic has 1 reply, 2 voices, and was last updated 1 hour, 53 minutes ago by
18 September 2025 at 13:17 #69740
Joris Allewijn
BRONZE MemberIn the “settings menu” on the screen of the BS5 I see: (translated into Enlish from Dutch)
Hostname: BeoMaster
IP-address: 192.168.1.119
customers connected: 0
Networkconnection: No
Bonjour-status: registration accomplished
Status Musicserver: busy
Name shared map: BM-SHARE$
Username: BM-User
My questions:
- “Why is the networkconnection indicated as “no”?
- Why is the status of the Musicserver on “busy”? Already for 2 months….
Thanks for replying if you are familiar with these settings.
Joris
You must be logged in to view attached files.Location: NetherlandsFavourite Product: Beosound 5My B&O Icons:18 September 2025 at 20:17 #69752GOLD MemberHi Joris, my fully working and connected BS/BM5 also shows a NO at NETWORK CONNECTION. The ‘Installation guide’ does have a section for ‘Testing the network connection’.
For the MUSIC SERVER status: maybe you can switch off (disable) the MUSIC SERVER, and see if the system still says that it is busy? In case you have it switched on, it could mean that the system is busy (or stuck) rebuilding the server, or just busy executing its server duty? Mine says DISABLED.
Regards, Johan
