Home › Forums › General Discussion & Questions › General Discussion & Questions › Beomaster 5: Networkinfo
- This topic has 5 replies, 3 voices, and was last updated 6 months, 1 week ago by
Joris Allewijn.
18 September 2025 at 13:17 #69740
Joris Allewijn
BRONZE MemberIn the “settings menu” on the screen of the BS5 I see: (translated into Enlish from Dutch)
Hostname: BeoMaster
IP-address: 192.168.1.119
customers connected: 0
Networkconnection: No
Bonjour-status: registration accomplished
Status Musicserver: busy
Name shared map: BM-SHARE$
Username: BM-User
My questions:
- “Why is the networkconnection indicated as “no”?
- Why is the status of the Musicserver on “busy”? Already for 2 months….
Thanks for replying if you are familiar with these settings.
Joris
You must be logged in to view attached files.Location: Netherlands
Favourite Product: Beosound 5
18 September 2025 at 20:17 #69752 TignumGOLD MemberHi Joris, my fully working and connected BS/BM5 also shows a NO at NETWORK CONNECTION. The ‘Installation guide’ does have a section for ‘Testing the network connection’.
For the MUSIC SERVER status: maybe you can switch off (disable) the MUSIC SERVER, and see if the system still says that it is busy? In case you have it switched on, it could mean that the system is busy (or stuck) rebuilding the server, or just busy executing its server duty? Mine says DISABLED.
Regards, Johan
19 September 2025 at 07:56 #69755Joris Allewijn
BRONZE MemberThanks for replying Johan. I will try this out. Let you know.
Greetz,
Joris
19 September 2025 at 15:43 #69765 carolpaBRONZE MemberHow about MOTS?
with large collections it will take a long time to complete!
so I would first switch of MOTS (if applicable) and see what happens.
And changes in the music collection or every restart interrupt the completion of MOTS.
20 September 2025 at 10:09 #69787Joris Allewijn
BRONZE MemberHi Carolpa,
On your advice I disabled MOTS. (Don’t use it anyway). I try and see. I will let you know and thanks foor replying.
greetz, Jos
30 September 2025 at 19:30 #70014Joris Allewijn
BRONZE MemberHi Johan and Carolpa,
I’ve disabled MOTS, but uptil now there is no change. I’ve indeed restarted the BM5 several times, so lets have some patience.
Another problem many of the BM5 users, included myself is SOLVED: It’s about the impossibility to make connection / drivemapping to the shared map “Music”. After a security update from Microsoft it was not possible anymore to connect in this way. Now, with the newly released update this is FIXED. See the reaction from Q&A from Microsoft:
“Ik ben Sumit, hier om te helpen met je vraag.
Excuses voor het ongemak – ik help je graag vandaag.
Er is één doorlopend probleem met betrekking tot netwerkshares. Microsoft heeft het opgelost met een optionele update die gisteren is uitgebracht.https://support.microsoft.com/topic/september-29-2025-kb5065789-os-build-26100-6725-preview-fa03ce47-cec5-4d1c-87d0-cac4195b4b4e
Installeer hetzelfde via Instellingen > Windows-update en laat het me weten.
