Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5 how to Hook up to streaming ie. Alexa Device
- This topic has 2 replies, 3 voices, and was last updated 1 year, 2 months ago by
SaltineSurfer.
1 August 2024 at 19:38 #57904
Sherry Paling
BRONZE MemberHave Beomaster 5 + Controller and a U-CONTROL UCA222 purchased from Steve at Sounds Heavenly.
How do I connect an Alexa device and get Auxiliary to allow voice activated music (for someone mobility challenged)?
Much appreciated?
2 August 2024 at 07:12 #57908Madskp
GOLD MemberYou will need a 3.5mm minijack to rca cable to connect the Alexa and UCA222.
Be aware that you have to activate the A.AUX on the Beomaster/Beosound 5 for the music to pass through that to the speakers, so you can not voice control the whole process
16 January 2025 at 11:04 #62748SaltineSurfer
BRONZE MemberHave Beomaster 5 + Controller and a U-CONTROL UCA222 purchased from Steve at Sounds Heavenly. How do I connect an Alexa device and get Auxiliary to allow voice activated music (for someone mobility challenged)? Much appreciated?
Hi Sherry,
Did you get this working? I have the same setup but find the music starts jittery on A.AUX for a few minutes then sorts itself out. I’ve tried different sources connected, and all the same.
Thanks.
