Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 5 connection to BV 9
- This topic has 2 replies, 2 voices, and was last updated 3 years, 8 months ago by
Ipe.
1 August 2022 at 06:54 #36538
Ipe
BRONZE MemberHi guys,
have problems with connecting bm5 to bv9.
What is the right way to do it? It’s visible but can’t use with remote (Beo4)
There is also BeoSound 5 connected but if I choose N.music with remote the tv screen shuts off.
Any good advice?
2 August 2022 at 12:17 #36539 bsantini1BRONZE MemberUse the PC command to view the beomaster 5 on the BV9
2 August 2022 at 17:11 #36540Ipe
BRONZE MemberBeomaster is already under pcs. In my case pc-command don’t work so it’s configured under DVD2/AV4. (pc is not highlighted / available on TV screen “menu/connctions).
So PC is AV5 but there’s no AV5 input in the tv or there is but it’s already in use for Beosystem 3 which is for the tv.
This of course mean also that I can not use remote to configure Bm. Is there some possible way to configure either bv or beo4? Some other on top of those I already know?
