Home › Forums › Product Discussion & Questions › BeoMaster › BeoMaster 5 A Aux source
- This topic has 2 replies, 3 voices, and was last updated 2 years, 5 months ago by
Steve at Sounds Heavenly.
15 October 2023 at 01:37 #49660
crewboss
BRONZE MemberHello,
I want play an analogue tv sound source through the BM5, but see no aux audio input.
Are the R & L sockets for audio output?
All suggestions welcome!
Thanks.
15 October 2023 at 16:08 #49661 Millemis
BRONZE MemberYou will have to use a USB soundcard like this.
P.S.
Yes, those are output.MM
15 October 2023 at 18:19 #49662 Steve at Sounds Heavenly
GOLD MemberThanks MM,
The USB adapter is great for audio sources, but unfortunately Beomaster 5 cannot work directly with a non-B&O TV.
If you connect a TV to Beomaster 5 via the USB adapter, there will be a delay to the audio from the TV, so that it will not match the picture (this delay occurs within the Beomaster 5 and it is a known issue with B&O). The only solution to this is to buy a Beolink Converter from Bang & Olufsen (type 1161166) and connect this to the Beomaster 5 with a Masterlink cable:
https://soundsheavenly.com/21-link-systems
In the BS5 menu, there is an “AudioMaster” submenu that needs to be selected as ON. There is also another menu just below it called “AM”, please set this to AM: 2 or AM: 6.
I can then help with a cable from the converter to the TV, depending on the audio outputs fitted to the TV.
Kind regards, Steve.
