Home › Forums › Product Discussion & Questions › BeoMaster › BEOMASTER 4500 Type 2961 repair – Power Fail or NTC issue ?
- This topic has 0 replies, 1 voice, and was last updated 6 months, 3 weeks ago by
Pirmin Weisser.
28 August 2025 at 11:06 #69127
Pirmin Weisser
BRONZE MemberHello,
I’m trying to repair a 4500 Type 2961 receiver/amplifier for a good friend. Error behaviour is that power relais for the amplifier power (+/-33V) switches off almost immediately after switching on which points to a Power-Fail or overheat condition (NTC). It also happens when no speakers an no other devices are connected.
When I switch on 20 times or so in a row, it usually switches on and works normally for several hours. After several hours of operation I powered down the unit over night but left it connected to the mains (rightmost LED on). And in the morning it switched on with the first try. Then I disconnected the mains for 1 hour and see the error behaviour again (relais switches off).
I should probably mention that for some time I have seen the unit “half-operable”: Radio part, amplifier abd remote control were working, but volume/sound control buttons did not work and also switching of sources did not work (only radio worked). That could have been a 8155 issue.
Anyone has ideas what it can be or what I can try ?
I would really like to helo my friend, since she likes the system so much. So any help is highly appreciated.
Thanks in advance
PirminLocation: Germany
