Home › Forums › BeoWorld around the world! › North America › Beomaster 4500 Software Update
- This topic has 4 replies, 3 voices, and was last updated 1 year, 7 months ago by
Bandobud.
18 April 2023 at 09:13 #45867
noahwmackBRONZE MemberHello!
I am wanting to modify my beomaster 4500 sw1.6 so it can work with 2 way control. Is there any way to do this?
Thanks,
Noah18 April 2023 at 21:28 #45868 Millemis
BRONZE MemberI doubt that you can get any of those chips anymore.
The best way would be to find another one with that version – most had it – and use that…..or use the unit instead of your own.MM
19 April 2023 at 02:37 #45869
noahwmackBRONZE MemberGotcha, where do you think I could find those?
19 April 2023 at 08:46 #45870 Millemis
BRONZE MemberA preused BM4500 should be easy to find……depending on your location.
Ebay or alike!
Or maybe at a ‘local’ B&O dealer.MM
4 September 2024 at 15:39 #58857Bandobud
BRONZE MemberHi Noah,
I realize this is over a year old post but just came across this and wanted to know if you ever found the BM4500 sw you were looking for. I have a chip that is sw 2.1 for BM4500 in the original case and B and O baggie if you’re interested.
Justin
