Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 4400 front disassembly
- This topic has 5 replies, 4 voices, and was last updated 3 years, 2 months ago by
Pindsen.
8 January 2023 at 06:07 #42641
Pindsen
BRONZE MemberHi,
How to disassemble the front of a Beomaster 4400?
In the two sides an undersunk screw can be removed but that does not loosen the upper front with the sliders because it requires to also remove the sccress in the middle and they are impossible to grab with a screwdriver – so how to remove the two screws in the middle? A solution could be to remove the whole front but that requires to remove the undersunk screw hidden behind the upper front part?
Looking in the service manual does not help.
Any good suggestions?
/PindsenLocation: Denmark
8 January 2023 at 20:27 #42642Dillen
ModeratorThe two screws can be accessed from below at an angle, through holes and passing boards etc.
9 January 2023 at 22:09 #42643 mexkingBRONZE MemberAs Martin says or use an angled (90 degrees) screwdriver, in mine they were missing
10 January 2023 at 21:29 #42644Pindsen
BRONZE MemberHi,
Okay thanx. They are not easy to get access to in general.
11 January 2023 at 08:47 #42645Evereddie
BRONZE MemberYou might take a look at https://beolover.blogspot.com/search?q=beomaster+4400
Scroll down and this may have the information you are looking for.
11 January 2023 at 19:37 #42646Pindsen
BRONZE MemberThank you, that makes it clear. It is impressive how much effort he put into his restoration projects 🙂
/Pindsen
