Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 4400, bump on the speakears
- This topic has 7 replies, 3 voices, and was last updated 3 years, 3 months ago by
chartz.
22 December 2022 at 08:49 #41776
lollo
BRONZE MemberHi to all, I’m an old enthusiast of B&O products. My collection began over 50 years ago with a wonderful Beomaster 5000. Then came the Beomaster 1400, 3000, 1900, 3300, Beossound 3000 mk2 and now the Beomaster 4400. I just bought this last one and it works very well but I have a doubt. When I turn it on there is a bump noise on the speakers. I ask you if it is normal because I saw from the wiring diagram that there is a relay but I think it is connected to the protection device and not instead to a delay in connecting the speakers to avoid this. Someone can please clarify this. Thank you.
Favourite Product: beomaster 4400, 3000, 3300
23 December 2022 at 15:12 #41777 chartzBRONZE MemberHi,
The bump is normal. The relay is on the PSU rails, not the speakers.
23 December 2022 at 18:07 #41778lollo
BRONZE Member- Ok, thank you. I found a stupid but easy way to avoid the bump. Just turn on the beomaster with the speakers unplugged :-). B regards
23 December 2022 at 18:24 #41779 chartzBRONZE MemberOr use the speaker switch, perhaps. ?
23 December 2022 at 19:49 #41780Glitch
BRONZE Memberlollo: You might want to put a multimeter across the speaker outputs and check the DC offset voltage. This should be very close to 0.0V. Sometimes power-on “thumps” are normal/unavoidable, other times they are indicative of something else. It is hard to judge what you are actually experiencing from the information that you provided.
Glitch
23 December 2022 at 22:16 #41781lollo
BRONZE Member- Ok, thank you. I will measure with the multimeter if there is Dc voltage on the speakers after switching on the beomaster. If so, it would be a regulation problem of the final stage of the amplification which should thus be verified and investigated. But probably the bump is normal as Chartz reported. Yes Chartz, I use the switch to disconnect the speakers :-).
23 December 2022 at 23:08 #41782Glitch
BRONZE MemberMy assumption was that you were experiencing something different than with your other/previous B&O receivers, otherwise you wouldn’t have asked the question. If there is an issue, there are multiple things that can cause a speaker thump.
Glitch
24 December 2022 at 08:48 #41783 chartzBRONZE MemberDon’t worry, the 4400 has it with 0 mV offset. Not a problem really. I’ve been hearing that thump every single day for 10 years now, ever since I restored it!
My 1967 Beolab 5000 has it too.
As an aside, the 4400 sounds extremely good, probably my best B&O receiver.
