Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 2400 radio hum
- This topic has 6 replies, 4 voices, and was last updated 2 years, 7 months ago by
jansjobe.
19 August 2023 at 02:31 #48328
jansjobe
BRONZE MemberI am restoring/repairing a Bang&Olufsen Beomaster 2400.
After a minute or so, I get a hum from tuned station, no hum between stations. Hum is propably 50Hz.
I have recapped all electrolytes.I suspect something wrong in the stereo decoder section. Could it be the IC itself?
Has anyone any ideas?
Best Regards,
Jan Sjöberg19 August 2023 at 17:09 #48329 Mark-sfBRONZE MemberDo you get the hum when you turn off FM Stereo? How about any other inputs?
19 August 2023 at 19:42 #48330jansjobe
BRONZE MemberThe hum is ONLY on FM radio.
At first the hum disappeared when switched to mono. Now it is still there, but slightly lower.
19 August 2023 at 19:42 #48331jansjobe
BRONZE Member20 August 2023 at 07:06 #48332sonavor
BRONZE MemberIf you unbolted the main PCB from the cabinet for the capacitor replacement, did you keep the FM tuner (metal box) secure? If the metal box was free to move while you were working it is possible a shield wire became disconnected…introducing the hum.
-sonavor
20 August 2023 at 07:14 #48333Dillen
ModeratorA bad rectifier D50 wouldn’t be a first.
Also, check the solder joints around the standby relay.Martin
20 August 2023 at 17:25 #48334jansjobe
BRONZE MemberIt was in fact the bridge rectifier!
Thanks everyone for your time and effort!
