Home Forums Product Discussion & Questions BeoMaster Beomaster 2400 instantly turns off when a channel is pressed
  • #123209
    mark2000
    This is the craziest thing. My Beomaster 2400 is suddenly turning itself off every time I turn it on. Instantly. If I press phono or tape or a radio channel it turns on for a half a second and then turns back off. I can even hear a radio station for a moment before it goes off again. It’s as if the O button is stuck, but it’s a touch surface so I don’t know how that’s possible. I have tried cleaning it. I took the batteries out of the remote. It’s still doing it. I tried unplugging it and plugging it back in. Same. Something has to be sticking somewhere or short circuited. It just happened after awhile of disuse.
    #123214
    Dillen
    There can be several reasons.
    DC on an output – typically if solder joints are cracked the output stage transistors.
    Bad switching IC – or oxide-shells between IC pins.
    Problem with the standby touchpad sensor circuit.
    Fault in a speaker or speaker cable. Try with no connected speakers/cables.
