Home › Forums › General Discussion & Questions › General Discussion & Questions › Beomaster 1900 – Volume control issue
- This topic has 2 replies, 2 voices, and was last updated 1 year, 10 months ago by
Asger Øllgaard.
9 May 2024 at 15:19 #55417
Asger Øllgaard
BRONZE MemberHello!
I’ve recently gotten my hands on a Beomaster 1900. Everything is working well – except the volume control. Whenever i try to turn the volume up on the touch panel, it stops at a certain volume. The light indicator doesn’t proceed to light up and the volume level stops when touch panel is pressed down.
Have any one of you had this problem before?
If anyone knows how to fix this problem it would be very much appreciated!Thank you in advance.
Cheers,
Asger9 May 2024 at 16:17 #55419Dillen
ModeratorDoes your volume control have one or two ICs?
9 May 2024 at 20:51 #55428Asger Øllgaard
BRONZE MemberHej Martin
After a couple of hours it magically fixed itself. It hasn’t been used in a long while, so it might have just needed a little warm up 😉
Thank you!
Asger
