Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1900 – No sound in left channel on phono/tape input
- This topic has 10 replies, 4 voices, and was last updated 2 years, 4 months ago by
mexking.
31 October 2023 at 09:22 #50033
ChrWorm
BRONZE MemberHello everybody.
I have a beautiful old Beomaster 1900 paired with two Beovox S45-2 speakers.
I have a problem with the left channel though.
When I press the FM-selector, sound is playing nice and normal from both speakers, and the balance-sliders works well, adjusting from left to right speaker.
When I am using the Phono or the Tape input, all sound disappears from the left channel.
I have an Beogram 1102 and a Beocord 1500, and the problem is the same with both devices.
I have just changed all of the capacitors and the lamps for the indicators, as I have read, that the problem could be with them. But the problem persist…
I have bought the capacitor-kit and lamp-kit from Beoparts.
Any advise on how to proceed?
Best Regards
Christian
2 November 2023 at 17:22 #50034ChrWorm
BRONZE MemberAs a sidenote I should mention that the problem is the same even if I use the output for speaker-set 2.
2 November 2023 at 22:51 #50035 mexkingBRONZE MemberI would start looking at the phono and tape preamp, Do the FM presets work OK
3 November 2023 at 00:19 #50036 Mark-sfBRONZE MemberFrom the diodes D200, 201, & 202 all three sources share the same circuit. So I would start by checking whether you have a signal on the anodes of D200 (Phono) and D201 (Tape). If not then I would trace back into their respective preamp circuits.
3 November 2023 at 00:25 #50037ChrWorm
BRONZE MemberThanks for the helpful input.
The FM presets work normal, sound coming from both speakers without any distortion.
I will try checking the signal at D200 and D201 as suggested and the preamp circuits.
Thank you in advance
3 November 2023 at 07:33 #50038Dillen
ModeratorWas this problem also present before you started work on the Beomaster?
3 November 2023 at 11:30 #50039ChrWorm
BRONZE MemberYes it has always been an issue, from the very start. It was the reason I changed the capacitors.
And because it have developed the classic humming, so I did an overhaul with a capacitor-set and new bulbs of the correct type?
3 November 2023 at 13:12 #50040Dillen
ModeratorA scope to the signal path would reveal the cause in a few minutes.
Lacking a scope you could compare DC voltages on the transistors in the preamp L+R sections.Martin
3 November 2023 at 15:20 #50041ChrWorm
BRONZE MemberI work as an automotive technian, so I have acces to an scoope.
I will begin to troubleshoot over the weekend, and get back when I have some more progress.
Thanks for the helpful input so far?
5 November 2023 at 20:45 #50042ChrWorm
BRONZE MemberProblem solved! Found som broken traces toward D200 and D201 on the board itself. Made a repair, and now the sound is perfect from both speakers?
Thanks a lot for all the help, fantastic!
6 November 2023 at 16:52 #50043 mexkingBRONZE MemberGood job congrats
