Home › Forums › Product Discussion & Questions › BeoMaster › Beomaster 1900 ( it just stays in standby mode)
- This topic has 2 replies, 2 voices, and was last updated 2 years, 1 month ago by
camiloastu@gmail.com.
9 February 2024 at 12:24 #52669
camiloastu@gmail.comBRONZE MemberHello,
I am working on a Beomaster 1900 and when I power up the equipment, only the standby light comes on, and the relay click is not heard. What should I check or replace to solve the problem?
Greetings
Favourite Product: Beomaster
9 February 2024 at 16:27 #52670Dillen
ModeratorNo relay click when you select a source?
Front panel correctly fitted? – If the bronze forks under the front panel does not grip
each their little pin on the circuit board, the touch fields will not work.Martin
18 February 2024 at 16:36 #52671 camiloastu@gmail.comBRONZE MemberHello Martín Thank you very much for your response, the device only keeps the Stand by LED on, I cannot select any source. The front panel is not installed. Greetings and thank you very much for your help
